585,975 active members*
4,402 visitors online*
    Mar 2008
    454
    4-axis SolidCam to Mach3
    Im new to 4-axis machining... 3-axis I'm comfortable with, but I'm having some trouble getting going with 4-axis.
    I'm using Solidcam 2010 & Mach3.
    Many videos on youtube show them picking a 4-axis post processor when loading the model... but my only options are:
    AWEA1000-FANUC
    FANUC
    Fanuc5a
    Nakamora-mt
    table-table-exercise
    How do I go about proper 4-axis milling?
    Quote Originally Posted by viroy View Post
    AWEA1000-FANUC
    FANUC
    Fanuc5a
    Nakamora-mt
    hi
    you must edit your default Gpp for 4axis
    if you want i can send standard 4 axis post for fanuc with 0to-360 and 0to360
    15362
    Re: 4-axis SolidCam to Mach3
    AWEA1000-FANUC
    FANUC
    Fanuc5a
    Nakamora-mt
    Any Fanuc code will work with Mach3 it just depends what machine the Post Processor was used for, there may be some editing to do of the code, so just try each Post Processor you have to see which works the best for your machine, the code is just Text so you can do whatever you want with it, you can edit it in Note pad and save it as Text and send it or load it into Mach3
    Mactec54
    Mar 2008
    454
    Hi Mhook, yes please I would like to try that.
  1. Solidcam 2018 Mach3 Sim.5 axis
    By atekinay in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-10-2020, 03:56 PM
  2. solidcam mach3 4th axis post processor
    By mioduz in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-07-2014, 01:04 PM
  3. MACH3 5 axis post for Solidcam?
    By mjb777 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-18-2013, 10:16 PM
