585,883 active members*
4,871 visitors online*
Results 1 to 6 of 6
    Oct 2008
    1632
    ST10/15 Turret alignment
    New to me machine.
    Leaving nubs when facing and small drills having hell. The BOT boring bar holders ALL are 0.010" to high. The Spindle Center line is correct and there is not any run out in the X direction, but it's like the entire turret rotated on it's shaft by 0.010". In other words, when dialing in a holder, the X+ and X- at 9 and 3 o'clock is fine, its the 12 and 6 o'clock that's off.
    There isn't enough offset on the cam bolt to move the holder down far enough. Haas tells you how to check alignment, but other than adjusting each cam eccentric on each position they don't mention anything else.
    Does anyone know anything about the turret, can the center be loosened up and tapped into place then tightened? How does one fix?
    Oct 2008
    1632
    Re: ST10/15 Turret alignment
    Maybe this will help someone out later. Evidently the machine I bought was crashed pretty bad and they went out of their way to cover it up.
    Hopefully they can salvage the Z axis Linear rails and ball screw.
    https://www.haascnc.com/service/trou...eo-series.html
    Jun 2015
    4154
    hy shim the face tool; the boring bars can handle those 0.010", unless you are frequently boring small internal diameters, like <15mm for example, and that will be tricky even on an aligned lathe
    as for drills, align a holder, and use it for coaxial operations / kindly
    Oct 2008
    1632
    Thanks, I thought about it. I also thought about sticking some bar stock in the turret and using the chuck to bore a 3/4" hole, then I could use ER Collet holder for the small drills.
    More cutting and testing shows it has more serious problems then just leaving a pip. It's cutting a taper as well and facing is concave. I could program around that if I "had" to but I'm not in a bind and I have several other machines I can use, so might as well fix it right. $$$$
    Jun 2015
    4154
    such a method may work, but is not certain
    you will hit into :
    ... play between hole you bored in the turret, and colet hoder od
    ... play beween coler holder id and collet
    ... play between collet abd tool shank
    * all those sumed up may hit arround 0.06, maybe more, maybe less ? not to count the paralelism, and others
    a pip is not a serios problem / just casual
    if you mean taper on z axis, then :
    ... it is normal, as long as your reference part is long, and you are using a tailstock; may be from tailstock ?
    ... it is not normal if your parts is short ( means that spindle is tilted )
    by long/short, i mean L/D ratio
    conical 0.03/100 should be ok; even 0.05/100
    facing is concave
    that may be because spindle and/or x axis is tilted
    no machine is squared, and a conical face maters more for bigger parts, so try to stick to small ones ?
    you have to check spindle if is it is tilted, and x axis, if it is no longer square to z; thus find how much is tilted each one, find the value; if you wish for guidance, pls share a photo with your lathe don't worry, if machine is tilted, it can be realinged, thus is nothing to worry about mechcanical / eletrical condition
    just as a side note, i can use 'skew' corections when programing, so to get arround fast with out of alignemnt lathes / kindly
    Oct 2008
    1632
    Bent Z rails, Bad Z screw, X axis was 0.018" out of square with Z. $10k later its cutting perfect.
  1. SL 10 turret alignment?
    By garylb in forum Haas Lathes
    Last Post: 08-12-2011, 03:16 PM
  2. turret alignment on sl 40
    By cherokeechief79 in forum Haas Lathes
    Last Post: 03-23-2010, 11:56 PM
  3. Turret alignment
    By jgrell in forum Turning Machines
    Last Post: 10-21-2008, 06:44 PM
  4. need help with turret alignment
    By wonder in forum Calibration / Measurement
    Last Post: 07-25-2008, 10:37 PM
  5. sl-30 turret alignment
    By bowhunter in forum Haas Lathes
    Last Post: 12-06-2007, 03:49 AM
