585,973 active members*
4,084 visitors online*
    Dec 2021
    Swapping sides for cables
    Ordered a new pro 4848 and would like to have the cables on the left rather than the right. Is that doable right out the box so to speak or would some machining be required ?
    Apr 2004
    326
    Re: Swapping sides for cables
    I think you should be ok, there is usually extra length in the cables. You will probably need to mount the control and spindle box on the other side as well. If you mount them on the outside of the frame, the switches will be facing away from you.
    Jan 2012
    222
    Quote Originally Posted by achtepa View Post
    Yep, put them on the side you want. The beauty of the DIY CNC Machines
    No machining or alterations required, btw. The machine is symmetrical for the most part so even the cable lengths shouldn't be an issue. Especially on a machine that small.
    Always check with the factory though to clear it with them.
  1. PP Memory Swapping
    By rdsi in forum Tormach PathPilot™
    Last Post: 01-08-2019, 07:09 PM
  2. Swapping out tube for solidstate
    By diyengineer in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-10-2018, 10:06 PM
  3. Swapping an axis
    By gregcoles@telko in forum CamSoft Products
    Last Post: 07-04-2013, 09:27 AM
  4. Swapping M3 and M4 in Fanuc 10T???
    By Andy Fritz in forum Fanuc
    Last Post: 01-25-2010, 06:20 PM
  5. swapping bearings?????
    By the4thseal in forum DIY CNC Router Table Machines
    Last Post: 12-13-2007, 02:20 AM
