585,727 active members*
3,999 visitors online*
    Mar 2008
    454
    Dial Indicator for 4-axis Rotary
    Howdy!
    I need a dial indicator in MM with an angle for a 3-axis tree mill with a 4th axis rotary.
    I already have a vertical dial indicator for measuring the Z-axis between the spindle and part/bed (straight up and down) which is great for 3-axis milling... but now I need one to measure between the spindle and rotary.
    I want to be able to rotate the part and see the changes in diameter... also need to be able to run the dial indicator down the shaft of the rotary to make sure it is flat or angled properly.
    So I need something that attaches to the Z-axis spindle, then leans to something between 45-90deg for dragging.
    Doesnt need to be super high accuracy... 0.001mm would be perfect, but I'll settle for 0.01mm too
    Can someone point out preferably an eBay item?
    Thanx!
    Dec 2013
    5717
    Re: Dial Indicator for 4-axis Rotary
    I think what you are looking for is a Dial Test Indicator (DTI). Normally the stylus is rotatable through 180 degrees or a bit more. 0.001mm? That's pretty high resolution, lab grade hardware. 0.01 - 0.02mm is reasonable for shop use.
    https://www.amazon.com/s?k=dial+test...f=nb_sb_noss_1
    Jim Dawson
    Sandy, Oregon, USA
    Mar 2008
    454
    Cool, found and ordered one
  1. indicator dial
    By Buba b in forum Fanuc
    Last Post: 11-29-2017, 04:57 PM
  2. Dial Indicator
    By hive8 in forum Benchtop Machines
    Last Post: 06-18-2012, 10:59 PM
  3. I can use a drum dial as a dial indicator can't I?
    By slashmaster in forum Benchtop Machines
    Last Post: 11-03-2010, 06:10 AM
  4. Dial indicator question
    By cwm9 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 12-17-2008, 09:15 PM
  5. Dial indicator
    By hkrok in forum News Announcements
    Last Post: 08-17-2007, 01:49 AM
