585,744 active members*
4,286 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > File Transfer from 3.5 Floppy
    Jun 2014
    5
    Hello all. I have an easy question but it sure has kicked my butt. I have an older HAAS SL-20 lathe that has a 3.5 floppy drive for file transfers. I need to transfer a file from the floppy to the lathe's memory and don't know how to do this. I can copy to the floppy from the lathe but I need to know how copy from the floppy to the lathe. Thanks Jon
    Sep 2022
    9
    Re: File Transfer from 3.5 Floppy
    Press (List Prog) button
    Blinking dot should be in bottom left corner
    Type File Name:----Example Only----(1234.txt)(1234.nc) or whatever you named the file with the proper file extension.
    Press F3 Button (Disk Read)
    If program loads it should be in the active memory.
    Hope this helps, MegaMoog
    Jun 2014
    5
    That worked today. I might have a disk going bad, it didn't work yesterday. Thanks for the help. Jon
    Apr 2018
    9
    It's pretty hard to find a working floppy these days. Get floppy-USB emulator adapter, they are pretty cheap and will save lot of your nerves.
