585,956 active members*
4,417 visitors online*
    Aug 2022
    23
    Emergency Stop
    i finally got my emergency stop-switch which i wired right to the E-Stop-Input on the MK3/4 Board and the ground. But nothing happens. What do i have to configure in the TNG to use it? I wired it up as Input and configured a shortcut - it works. But i got an extra E-Stop-Inlet and want to use it. But how?
    Mar 2017
    1311
    Re: Emergency Stop
    Settings/Input/Output/EStop Pin -> Enable
    Aug 2022
    23
    Re: Emergency Stop
    Thanks, that was an easy one.
    24221
    Re: Emergency Stop
    Advising the system that an E-stop occurred and relying on the S/W system to implement an E-stop is not enough in itself.
    Technically you should have a hard stop also that immediately removes all power to motive devices, i.e. the power to all servo's and motors, spindles etc, should be opened.
    This according to NFPA79 reg's.
    Albert E.
  1. Problems with Emergency Stop/Stop function.
    By MrEmo in forum PlanetCNC
    Last Post: 10-19-2021, 10:47 AM
  2. emergency stop condition after E stop
    By Cosmin90 in forum Fadal
    Last Post: 01-14-2020, 01:30 AM
  3. Generic Emergency Stop (E-Stop) Design Concepts?
    By zipzit in forum CNC Machine Related Electronics
    Last Post: 06-09-2011, 12:14 PM
  4. Emergency stop
    By Franky42j in forum Philips
    Last Post: 08-20-2008, 03:16 PM
  5. emergency stop
    By natchez in forum Xylotex
    Last Post: 06-16-2005, 02:27 AM
