584,861 active members*
4,861 visitors online*
Results 1 to 7 of 7
    Apr 2009
    22
    ITNC 530 question M140
    If i command a M140 after the TOOL CALL will it create an issues? I would like to do this to make sure there is Z retract before rotary axis re-positioning on restarts.
    *B0 C0 ROUGH WAVE GUIDE 1
    ;0.09375 EM 0.300 LOC
    TOOL CALL 64 Z S30000
    M140 MB MAX ****
    ;MAX - Z+.3247
    ;MIN - Z-.2048
    CYCL DEF 32.0 TOLERANCE
    CYCL DEF 32.1 T0.0001
    CYCL DEF 32.2 HSC-MODE:0
    Mar 2016
    322
    Re: ITNC 530 question M140
    there can be a problem with MB only if there won't be enough space to move to programmed retract.
    Apr 2009
    22
    clearance is no issue. I just want to ensure it doesn't cancel any tool length information.
    Apr 2009
    22
    Also, is these a command goe sending a machine to axis extent? Like a Fanuc G91 G28 Z0
    Mar 2016
    322
    Not exactly. It goes away along tool axis. So if the plane would be tilted it won't move back along Z as G 28.
    Mar 2016
    322
    And it won't mess with tool length either.
    Apr 2009
    22
    thank you for the help. Have a great day.
  1. Need PP iTNC 530 for MC X8
    By ravenswing in forum Post Processors for MC
    Last Post: 12-03-2020, 11:17 AM
  2. iTNC 530
    By dsmythe in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-19-2015, 03:48 PM
  3. itnc 530
    By achsexyz in forum HEIDENHAIN -> GENERIC
    Last Post: 02-12-2012, 07:18 PM
  4. iTNC 530 on the PC
    By Master12 in forum HEIDENHAIN -> iTNC530 PC-SOFTWARE
    Last Post: 09-11-2011, 04:04 PM
  5. Heidenhain iTNC 530 question
    By Brian Brown in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-19-2010, 10:53 PM
