Re: Surface grinder CNC refit
I have a DoAll of similar size sitting in my shop waiting for a CNC retrofit, also hydraulic, so I have a very good idea of what you want to do. I assume that grinder has a hand wheel for the X axis also, which would imply it has a rack & pinion on the table. I would remove the hydraulics and add a stepper drive for the X axis also, using the existing rack & pinion.
The Automation Direct stuff seems rather expensive for the application, and everything is on backorder. It looks like the DL205 with the H2-CTRIO motion module would drive the steppers. Interfacing with the touch screen panel is no problem using the Automation Direct provided software. I haven't programmed one of those in over 20 years so I don't know what the capabilities are today.
There is no really good off-the-shelf software solution for this application, I am just going to write my own and use a Galil motion controller as the brain and a mini PC as the user interface. It is possible to run a surface grinder with conventional G code, so something like Mach3 might be an option. Mach3 handles loops in the G code quiet well, needed for the step over / step down. On the other hand, purpose written software is the real answer to operating a surface grinder because they operate differently than any other machine tool.
You might also look at:
Centroid https://www.centroidcnc.com/
Dynomotion https://www.dynomotion.com/
CamSoft PC Based CNC Controller For The Machine Tool CNC Retrofit And CNC Controller OEM market
But to your original question of where to start. Choosing the control system will come later. First take an inventory of what electrical hardware you have there now, figure out what you can reuse and what you need to buy. Write down the functionality you need, then figure out how you are going to achieve that goal. Create an electrical diagram of what you need to run. Download the user manuals from Automation Direct to see what you are getting into, their documentation is great. Look at the software suggestions above also, and download any available user manuals. The question you want to answer is: ''Can I make this work?'' Once you have done some research, then it's time to choose a control system.
I'll be happy to try to answer any questions.
Jim Dawson
Sandy, Oregon, USA
