585,679 active members*
4,922 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Need to finish this large scale X axis gantry. I'm stuck. any suggestions
    Nov 2018
    53
    Greetings!
    I can really use some advice and some engineering*help.* I have been working on this large scale clay printer for way to long. I have all the electronics, electrical and motors working. I have all the bones.* I am just stuck at a couple points. I need some form of GANTRY for the X axis. The X axis is 6' long made of an aluminum I-Beam with 2" tubes. I have a Nema 23 running a HTD5M Polyurethane 15mm belt.
    My current design uses Skate wheels on a 5/16" all thread shaft. I 3D printed brackets for them. I was thinking of using 2 sets at the top and on set at the bottom like a desktop 3D printer. I can move up to 4 sets.
    So here is where I am stuck. I don't have a good way of tensioning the belt. I found these nice 3D printable clips that have 1/4-20 bolts that can tighten the belt from the gantry plate. Unfortunately, they are kind of thick, and I don't have enough clearance from the belt to the center aluminum cross beams.
    I guess I can go back to try and tension the belt from the pulley side. But there is not that much clearance.
    I'm not sure how tight the belt should be.
    Next, I could use some advice on the gantry plate, how to mount the belt to it, and then once I have the wheel carriages attached, how I can tighten them?
    I was thinking springs?
    Don't really have a concentric nut option?
    If I go with the 2 sets at the top and one set at the bottom, I could have the bottom wheel set on a pivot from the top, and Maybe use some all thread from the bottom to the second top set of wheels.
    I really just need to get this finished so I can move on:-)
    I'm so close.
    Any ideas would be greatly appreciated.
    Max Webber
    Apr 2004
    5734
    Re: Need to finish this large scale X axis gantry. I'm stuck. any suggestions
    Maybe this article will give you some ideas: https://www.tec-science.com/mechanic...r-belt-drives/
    Andrew Werby
    Website
    Dec 2022
    Mate, for my sorrow, i cant rly help u with advice, all i know that any problem cand be solved in discussion with proper community. I'm sure u might find usefull contacts or info at somekind of cofounders platform and search more info about CTO as a Service . Yeah, looks kinda rude to distruct u with such as method, but it may bring new solutions to you and reveal some new stuff u've neve met before.
  1. Need suggestions on large scale 3d printer build
    By Tristar500 in forum 3D Printer / 3D Scanner Discussion
    Last Post: 02-09-2021, 10:15 PM
  2. Help me design a large scale 4th axis machine!
    By Gyropilot in forum Other Machine Topics
    Last Post: 02-01-2019, 09:40 PM
  3. Advice on my Large Scale Z axis
    By disneytoy2 in forum Linear and Rotary Motion
    Last Post: 01-18-2019, 11:43 PM
  4. Replies: 1
    Last Post: 10-02-2015, 05:34 AM
  5. Heavy large scale gantry mill/router/3d carving 5 axis build
    By Tristar500 in forum DIY CNC Router Table Machines
    Last Post: 03-18-2010, 12:07 PM
