585,894 active members*
5,082 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Measure surface height - DRO not being set.
    Mar 2005
    8
    Hi all,
    I am having issues with measuring the surface height using a 3 way edge finder. The plate is 10.24mm thick and I have entered this value into Work Position/Measure Height, Size Z. When I select Machine, Measure, Surface Height - the Z axis moves down until contact is made with the plate, reverse up, moves down at lower speed, contacts plate and returns to preset height. The DRO is not set automatically in this operation to the plate thickness.
    Has anyone experienced the same issues and what might be the cause of the issue.
    Thanks in advance.
    Steve
    Mar 2017
    1310
    Re: Measure surface height - DRO not being set.
    This command does not set offset. Use "Machine/Work Position/Measure Height" instead
    Mar 2005
    8
    Thanks of the reply. I have had to btravel away for work for the last 2 weeks. I will try your suggestion.
  1. How to set zero for torch height
    By kxkid in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-10-2013, 01:41 PM
  2. Problem with Drive Surface Height
    By declanhalpin in forum MadCAM
    Last Post: 04-04-2013, 08:33 AM
  3. measure the flatness of a flat surface
    By faltklo in forum HEIDENHAIN -> GENERIC
    Last Post: 04-04-2012, 05:12 PM
  4. New DRO set up on X2 mill
    By chronic in forum Benchtop Machines
    Last Post: 07-02-2010, 05:09 AM
  5. How do you set the rapid height on Z
    By dcdavid in forum Uncategorised CAM Discussion
    Last Post: 09-08-2009, 02:05 AM
