Hi guys.
Its been slow progress again, this time with the lubrications lines.
So the lubrication lines are blocked, I have pulled a few lines out and unclogged them but the other lines are difficult to access.
I have cleaned out the oil tank, replaced the oil pump motor and is working well but unfortunately the X and Y line are blocked and im hesitant to use the machine until these lines are ok. (I have manually oiled the X Y slides)
So just wondering is there a cleaner I can pump through the lines? I read on the internet some people using ATF im guessing that is automatic transmission fluid? Is Kerosene ok? Will this harm the seals or the plastic oil lines?
Any advice would be great, but im really trying to avoid pulling the table off get to the other oil lines.
Bart
