hi
i am machining a part on a 5 axis, using rotary programming, first of all, i check the OD to see it is true by rotating the table
I probe the O/D to check the run-out of the part with 8 points, i have given each of these points a Q parameter
is there a function in Heidenhain which will find the biggest number of all these points?
