585,978 active members*
4,430 visitors online*
Thread: XYZ Probe
Results 1 to 9 of 9
    Sep 2022
    4
    XYZ Probe
    Hello,
    We are a Fablab in Brussels with an old CNC retrofitted with a planet CNC controler and, at the moment, a simple Z probe.
    We'd like to add an homemade XYZ probe like this one https://ooznest.co.uk/product/origin...z-touch-probe/
    (that could idealy correct for deviation if the workpiece is not straight but a simpler one would be fine as well)
    I looked on the forum but couldn't find enough info on the custom scripts and the wiring needed for that.
    If anyone can point me in the right direction !
    Thank you in advance,
    Arthur
    Nov 2015
    260
    Re: XYZ Probe
    Take the following one:
    https://a.aliexpress.com/_Eug9gvD
    all scripts out of the box in TNGv2
    Sep 2022
    4
    Re: XYZ Probe
    That looks good but we were looking for something to make oursleves, also this one requires changing the tool, with the other just using the current tool is enough
    Apr 2022
    12
    Re: XYZ Probe
    For the first steps you could take a look at
    https://planet-cnc.com/measure-work-...ovable-sensor/
    Sep 2022
    4
    Re: XYZ Probe
    This one we got working, I was just wondering if there was a comprehensive tutorial on an XYZ probe with planet CNC
    Aug 2020
    131
    Re: XYZ Probe
    The mentioned 3d probe is more than worth the effort to change the tool for measurement.
    It works much better. Does not require any offsets and works with every material. And you do not run the risk of plunging your endmill into the workpiece.
    Sep 2022
    4
    Re: XYZ Probe
    I undestand it's advantages but it's not appropriate for our use. It's a shared CNC and we feel the plate would be more appropriate. And if it turns out it's not we will have learned to make it work So if anyone has a tutorial on how to make a such a probe work with planet cnc I'm still interested !
    Sep 2016
    5
    Re: XYZ Probe
    Quote Originally Posted by lgritsch View Post
    Can you help with that probe??
    How connect and how use it with planet cnc?? how setup? script?
    Aug 2011
    252
    Re: XYZ Probe
    Quote Originally Posted by Agld View Post
    I don't think there is a tutorial on this, but you can use a similar plate as a probe with PlanetCNC probe function from the program. You don't need the hole in the plate. Set probe pin NO and probe dimensions for X, Y, Z and speeds. Also measuring with a tool in spindle is not precise, you need to use some precision round bar for measurements. So for that particular use of the plate, you will use Machine->Measure->Outside Corner where you can check Set WO (work coordinate). The tool or precision bar will go down touch the plate, then will move to X and Y (distance you specify at Edge) to measure the edges. Don't worry if distance is to short it will touch again the surface and move side way till it can go lower for edge measure. Pay attention at direction selection of the corner you measure. Always before to use the plate check the contact in IO panel.
  1. XYZ Probe modification
    By erniebro in forum Mach Wizards, Macros, & Addons
    Last Post: 09-22-2022, 07:44 AM
  2. g-code for probe (xyz)
    By thewillow in forum Australia, New Zealand Club House
    Last Post: 07-22-2020, 01:19 AM
  3. mp10 xyz probe cycles
    By dec11ad in forum Okuma
    Last Post: 03-01-2020, 11:48 PM
  4. programing xyz probe to xbox 360
    By tiofilo123 in forum Mach Wizards, Macros, & Addons
    Last Post: 07-25-2011, 05:54 AM
  5. connecting xyz probe to xbox360
    Last Post: 07-25-2011, 05:29 AM
