585,975 active members*
4,529 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Serial communication (MODBUS) with PlanetCNC TNG - tutorial series [UPDATED]
Results 1 to 14 of 14
    Mar 2017
    1311
    Serial communication with PlanetCNC TNG - tutorial series
    We published first part of the tutorials about serial communication.
    As a final goal, we intend to control external relay board using MODBUS.
    If you have any questions, tips or suggestions, let us know
    https://planet-cnc.com/serial-commun...nc-tng-part-1/
    Best regards, Team PlanetCNC
    Mar 2017
    1311
    Re: Serial communication with PlanetCNC TNG - tutorial series
    Part 2 has been published. It describes serial functions :
    https://planet-cnc.com/serial-commun...nc-tng-part-2/
    Apr 2016
    19
    Getting modbus is a big deal. I am no software person, but I know multiple motors, pre-positioning conveyors, and wego i/0 systems all work well on modbus. Ethercat, meh. Heavy bus (one control for everything) is good for simple stuff like a mill, a router, a drill.
    The wego i/o would be big. especially if we can get Planet to respond to real(ish) time feed back.
    Aug 2020
    131
    Any Plans to support VFD Control via modbus for starting/stopping the Spindle and controlling the spindle speed?
    And maybe to get some informations back from the vfd?
    Especially the spindle Speed is something that can't be easily controlled with own gcode as its requires changes to the S word.
    Mar 2017
    1311
    Yes, this is on my TO/DO list, I plan to write tutorial for such application.
    I will use a Chinese VFD for an example.
    Everything needed to this is already implemented. All that is missing is tutorial.
    Aug 2020
    131
    sounds great, looking forward to it.
    Mar 2017
    1311
    Re: Serial communication with PlanetCNC TNG - tutorial series [UPDATED]
    Part 3 has been updated. It demonstrates actual process on how to communicate with modbus relay board:
    https://planet-cnc.com/serial-commun...nc-tng-part-3/
    Mar 2017
    1311
    Re: Serial communication (MODBUS) with PlanetCNC TNG - tutorial series [UPDATED]
    Part 4 has been published. It demonstrates advanced expression function use and more structured code design:
    https://planet-cnc.com/serial-commun...nc-tng-part-4/
    Mar 2017
    1311
    Little update:
    (pseudo)MODBUS communication control of Chinese HuangYang VFD is already in testing phase and indeed it looks promising.
    We will post tutorial article and all necessary code in order to control VFD, using MODBUS and TNG software.
    Quote Originally Posted by PlanetCNC View Post
    Little update:
    Any update on when this VFD modbus example will be shared?
    Mar 2017
    1311
    Next week for sure! I just need to test it a bit more and make more robust.
    Great thanks
    Quote Originally Posted by Sparkrobotic View Post
    Great thanks
    Do you have sample code we could look at?
    Mar 2017
    1311
    Tutorial has been published.
  1. Replies: 3
    Last Post: 02-04-2023, 06:14 PM
  2. PlanetCNC TNG - License issue, PLEASE READ!
    By PlanetCNC in forum PlanetCNC
    Last Post: 08-09-2022, 07:18 AM
  3. Gantry square procedure tutorial with PlanetCNC TNG
    Last Post: 07-08-2022, 12:01 PM
  4. Replies: 0
    Last Post: 07-06-2022, 04:17 PM
  5. Issues with PlanetCNC TNG
    By nucutza in forum PlanetCNC
    Last Post: 11-19-2017, 10:23 AM
