585,555 active members*
3,044 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > HELP WANTED VMC1000 Siemens MotorEncoder commpatibility
    Jul 2013
    36
    We have a Bridgeport VMC 1000 and we are replacing the spindle motor.
    Our Motor is a Siemens 1PH6135-4NF49-Z. the name plate on the motor says it has a RON 350 2048 encoder
    The replacement motor we found has the same part number but it has a different Encoder ERN1387 2048.
    For sure the 2048 is the resolution. I can`t just switch the encoders because the Ron Encoder has a Female
    drive while the ERN encoder has a male drive. Do not wish to make an adaptor since this would require the cooling fan
    seating to be modified.
    The RON350 is fitted on an Analogue Dive so I assume its analog but I do not know why the same motor with different
    Encoders. I have looked everywhere and got hold of a ERN Encoder datasheet but not the RON datasheet.
    Anybody can assist me please.
    24220
    Re: HELP WANTED VMC1000 Siemens MotorEncoder commpatibility
    IIRC the ERN series has a 1v peak to peak sine wave output, the RON series is 5v square wave out, so you would need to convert it .
    You could also contact Heidenhain for the info on the RON 350 2048 to be sure.
    Albert E.
  1. SIEMENS PDF wanted.
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 08-30-2015, 03:00 PM
  2. bridgeport vmc1000
    By bikeer in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2015, 11:46 AM
  3. hardinge vmc1000
    By samu in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2012, 05:55 PM
  4. Bridgeport VMC1000
    By Welshsteve77 in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2010, 10:03 AM
  5. VMC1000 Troubles
    By Kiser in forum Bridgeport / Hardinge Mills
    Last Post: 07-07-2009, 04:01 AM
