585,762 active members*
4,037 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Interact 720 What speed can the spindel take ?
Results 1 to 11 of 11
    Jun 2011
    61
    Im updateing my Intercact 720 with more modern motors and everything !! No more parameter worries batterie wise etc . I would like to update the spnidle drive motor withn a modern DC motor , the question is can the bearings take it , going from 4000 rpm to 18000 rpm , I dont suppose I will use the 18 grand , I can control this , but 8 to 10 grand would be nice for aluminium .Any thoughts at all would be appreciated thank you .
    24220
    Re: Bridgeport Interact 720 What speed can the spindel take ?
    The only DC motor that would operate at this RPM is either a BLDC or a Universal (Router) style AC/DC motor, your run of the mill ordinary brushed PM DC motors do not operate this high, generally.
    If you have AC in order to run the Universal motor, then there is a variable speed drive touted on one of the forums here, the SuperPID controller which gives you feedback control down to 5krpm.
    This has the Heidenhain control on it, right?
    Albert E.
    Jun 2011
    61
    Thats what I was led to belieive but Ive found a company in europe whoi make such unit , and no Heidenhain unit any more plug in Laptop , job done .No more 1989 computer hightech ! the DC brushless motor has 5.5 kw revs to 18000 , will update when fitted and tried and tested .All the XYZ motors are also DC small and and lot more powerfull . and work really well .Now the spindle motor .
    24220
    Quote Originally Posted by beemergb View Post
    Thats what I was led to belieive but Ive found a company in europe who make such unit "the DC brushless motor has 5.5 kw revs to 18000 , .
    As I said BLDC
    Albert E.
    Jun 2011
    61
    Yes sorry I didnt recognize the abbreviation , Im not a tech guy my friend is doing all the clever stuff ! Im just machining all the race parts for him ! When it runs !
    Jun 2011
    61
    By the way do you know if the spindle bearings can take such high revs ?
    24220
    AFAIK It is rated at 6krpm, so you may be pushing it, at that high a RPM.
    3x rated RPM !!
    Albert E.
    Jun 2011
    61
    AFAIK , is that the bearing company that manufacture these ?
    24220
    AFAIK = As Far As I Know. !
    Albert E.
    Jun 2011
    61
    Thnx M8
    Oct 2022
    FITA Academy AWS Training is an integrated professional course that focuses on teaching learners AWS (Amazon Web Services), Amazon's cloud computing subsidiary that includes a wide range of tools, services, and functionalities that provide cloud-based services in the IaaS (infrastructure as a service), PaaS (platform as a service), and SaaS (software as a service) domains.
    AWS Training in Chennai
    AWS Online Course
    AWS Training in Coimbatore
  1. Bridgeport Interact 720 Retrofit
    By beemergb in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2022, 12:34 PM
  2. Bridgeport Interact 720
    By Monte Godwin in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2022, 01:26 PM
  3. Bridgeport 720 Interact
    By beemergb in forum European Club House
    Last Post: 06-08-2014, 04:03 PM
  4. Bridgeport Interact 720
    Last Post: 04-08-2013, 08:13 PM
  5. bridgeport interact 720
    By foseguera in forum Post Processors for MC
    Last Post: 01-18-2010, 05:04 AM
