Hi all,
I have a delta 20 control on a Clausing Kondia FV-1. I've been able to successfully load programs into the control using the RS232 port. When I try to export programs or tool tables back out of the Dynapath, it appears to be working on the control (it runs through the line numbers as it progresses), but no data shows up on the receiving end. I've tried starting the transfer both on the control end vs the receiving end first, neither seems to make a difference. The settings are the same between loading and recording.
Any suggestions would be much appreciated!
Lee
