585,749 active members*
4,008 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > M axis orient function
    Aug 2011
    419
    Hi
    Has anyone ever used this function on a c-axis machine?
    I don't understand how it is work!!
    "Imagination is more important than knowledge."
    Apr 2009
    1262
    Re: M axis orient function
    Typically it is used for a boring operation so that you can retract without dragging your boring bar. Orient, shift away from orientation, retract.
    Experience is what you get just after you needed it.
  1. Lathe C-axis simultaneous function
    By siberiansun in forum Fanuc
    Last Post: 02-10-2013, 06:35 PM
  2. Has anyone used the 5th axis function
    By Don C in forum Uncategorised CAM Discussion
    Last Post: 10-04-2012, 10:08 PM
  3. Z axis height as a function of Y-axis position..
    By bo.gardmark in forum PCB milling
    Last Post: 06-07-2012, 07:55 AM
  4. function of the Z axis
    By jochesfor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-11-2008, 08:06 PM
  5. Spindle orient and A axis smoothing
    By 1ctoolfool in forum Haas Mills
    Last Post: 11-23-2006, 05:38 AM
