585,996 active members*
3,850 visitors online*
Page 2 of 3 123
Results 21 to 40 of 42
  1. #21
    Apr 2004
    5737
    Re: Oiling the ER collet nut?
    Quote Originally Posted by gimpo View Post
    @awerby
    Yes, I snap the tool inside the collect.
    I do not know the reason: but sometimes I get perfect vertical "walls" after a sping-cut, sometimes not. But the tool is the same... (usually a 3 or 4 mm dia in an ER20 collet).
    I'm investigating about the possible causes of lack of "perpendicularity".
    That's not what I said. You don't snap the tool inside the collet. You need to snap the collet inside the nut. If you look down into the closer nut, it will look irregular. That's on purpose. You need to push the collet in there with a bit of force; you'll hear a little click when it's properly seated, and then when you turn it over it won't fall out (if it does, try again). Only then should you insert the tool into the collet and tighten it down. Then it will stay in there straight.
    Andrew Werby
    Website
  2. #22
    Jun 2022
    24
    Just ordered one ER20-4mm collect from FAHRION.
    Maybe too much pricey? But I want to check if a good/top quality collet is the right direction to solve my problem, before buying a complete set of new collets. Otherwise, I simply wasted my money...
    P.S.
    A complete set of ER20 collets is shown on the Kintek catalog, but how to buy them online?
    I presume they are "medium quality" collets, but better than the chinese stuff sold on ebay in any case.
  3. #23
    Jun 2022
    24
    Quote Originally Posted by awerby View Post
    My typing error. Sorry.
    I got what you meant.
    Do you usually assembly collet+nut+tool and then you insert them all in the spindle end? Or you first fit/screw collet+nut, and after you fit the tool?
    What is the best procedure to make the tool sitting more vertical as possible?
    I usually try to fit collet+nut+tool all together in one step... but I'm not sure this makes any difference.
  4. #24
    Nov 2013
    4372
    the real advantage of the snap ring is when you go to release the tool.
    Once the tool is inserted and the nut tightened the taper clamps up, and even undoing the nut won't release the collet in the taper. The snap ring however is in a groove in the collet and so if you undo
    the nut a turn or so it will 'pull' the collet and cause it to release from the taper. Removing tools would be a major PITA without that simple but clever snap ring.
    Craig
  5. #25
    Jun 2015
    4154
    if it matters, kinteck's er20 variants are :
    ... mechanical sealed, tir < 0.01
    ... not sealad, tir < 0.01, clamping range 0.5 , 1, standard length + 2 more variants
    ... not sealad, tir < 0.005
    ... ruber sealed, tir < 0.01
    ... ruber sealed, tir < 0.005
    i am not here to sell kintek, or to argue about their quality, as being medium or not
  6. #26
    Jun 2022
    24
    There is an online distributor/vendor of Kintek stuff, or I have to contact them directly by email?
  7. #27
    Jun 2015
    4154
    if i may, one more thing : for a nut to remove the collet, is not necessarly to 'snap' before mounting
    keep the nut in your hand, then gently put the colet in it; next, flip the nut upside down, and the collet should fall to the ground; such a system has play for easy mounting, but yet can pull the collet away from the chuck; the trick is the nut ring shape and play with collet groove
    some producers make them so tight, that once you snap it, is really hard to take them apart
  8. #28
    Jun 2022
    24
    Craig
    Hello Craig,
    nice explaination!
    I don't know why a plain and simple description like the one you wrote is so hard to find on internet!
  9. #29
    Jun 2015
    4154
    hello control for collet chucks ( please check attached ):
    ... craft the green piece, basically a solid collet + arbor
    ... mark the chuck, then insert it in the chuck , then manual rotate it : is needed to see contact loss towards the botoom, towards the small diameters, thus to make sure that main contact occurs near chuck face
    ... check that orange distance, to be minimal, not only for this green part, but also when mounting collets; if it is too small, then recut the chuck face
    ... clamp the green piece, and check tir near and far, if it is not ok, then chuck cone has to be refreshed
    long term use of -1 range collets and solid nut, leads to wear, because of
    ... twist :
    ...... more pronounced wear : between collet small taper and nut
    ...... less pronounced wear : between collet long taper and chuck, especially towards the chuck face, because original product is designed to make contact towards the face; if this area gets wear, then tir will appear
    ... drag : like besides twist, the collet had a tendency to scracth the ( slide in ) chuck inside cone, longitudanlly
    when h7 range collets, and bearing nuts are used :
    ... twist does not occur
    ... drag occurs, but is minimized
    * wear manifests later, for both chuck & collet
    for same force aplied, a collet with more grooves will deformate more than a collet with less groves, so they will stick diferently to the chuck, thus when reversing the nut, to unmount them, the collet with more groves will be easier to pull out; as a side note, the collet with bigger range, has to be softer than a collet for h7 range, otherwise it will break into pieces; as a consequence, the collets with less groves and less range ( thus precision collets ) make stronger contact with the chuck, so if they are tighetened with a normal nut, then, they won't rotate inside the chuck as much as a many grooves collet does, and this means that during the last few turns of the nut ( or the last 1/2 turn ), the collet being static, wear will appear in the contact area with the nut
    thus is better to use a static nut on a high range collet, instead of a precision collet, or you'll scracth those precision collets too fast, but those may still work, as long as the nut won't be able to tilt them inside the chuck cone; a precision collet is harder to tilt, while a big range collet is easier, being less resistive
    as for threads, precision assemblies, are designed to rotate and fix after a predefined number of turns, preferably minimal; if the number of turns is bigger, then the nut will have the tendency to still rotate for a bit too long, after the collet has allready being fixed in the position; this means that, if someone is stronger, he will torque that nut for too much, while, with a precision assembly, he won't be able to torque it any futher, because it allready blocked mechanically
    this type of precision is not comonly found in er systems, but more in gang systems, for collet chuck spindles, that fix/blocks after a small amount of turns; but is one reason why some quality collet vendors recomand their chucks and nuts, so to achieve minimal tirr,
    as a conclusion, in the end, you may trust the vendor/dealer as he sais that he has quality, or better have in house control/methods; i mean reliable methods, proven, because, for example, simply a dial inside the chuck does not mean that the chuck runs true; you have to tram it somehow; best quality methods do not evolve from final inspection of random products, but from knowing how to craft them tight, in repetitive manner / kindly
  10. #30
    Jun 2022
    24
    Quote Originally Posted by deadlykitten View Post
    Oh yes indeed, it is true.
    if you have perfect circle the cone is squared. Otherwise you would get an ellipse (an angled planar section of a cone) and your dial indicator would reveal it.
  11. #31
    Jan 2018
    1516
    I would use GT85 to clean the threads. I would NOT use oil, it attracts crap.
  12. #32
    Jun 2015
    4154
    hy gimpo that's right in theory, but in reality, the indicator in only one place, may not reveal that a part is tilted
    may sound weird, but in the end, is a L/D ratio thing related, and that's the reason why, when grinding for example, is needed to dial the od(or id) + a face ( if is not possible to dial a face, then there may still be variants )
    if you dial only the diameter, and the dial looks ok, this does not mean that the face is also ok
    going back to collet chucks, during their manufacture, is possible to deliver them without making the face square/true with the inside, and a consequence, is that later on, for example when it reaches the client, it can be tricky to check the chuck condition
    take a cad you like, take a cilinder, and intersect it with a plane : result will be a circle; if you tilt the plane only a bit, the result is an ellipse, but in reality, you can not detect that ellipse, unless it is far away from a circle enough, so that the dial will detect it; thus the real moment when your dial shows an ellipse, is when you part is tilted too much, like out of spec
    same happens also with a cone : when plane is perpendicular, intersection is a circle, while in reality, at the moment you will detect an ellipse, the cone will be tilted too much
  13. #33
    Nov 2013
    4372
    That is true but the sensitivity of the measurement is very poor.
    Lets imagine that the circle described by the internal taper with the spindle perfectly trammed is 25mm in diameter. Now if the spindle were 1 degree out of tram the major diameter
    would still be 25mm but the minor diameter would be 25 x cos(1)=24.9962mm. Thus a one degree tram error results in a dial indication of only 3.8um.
    I would expect to tram a spindle to within 15 min of arc, for a dial indication of 1um or so. The indication is not sensitive enough to be of practical value.
    Craig
  14. #34
    Apr 2004
    5737
    [First snap the collet into the nut. Only then should you slide the tool into the collet. Then tighten the nut onto the spindle nose. If you want, you can put the nut/collet assembly onto the spindle nose and then insert the tool and tighten.]
    [It doesn't work "all together in one step". It sounds like that's the cause of your problem.]
    Andrew Werby
    Website
  15. #35
    Jun 2015
    4154
    hy gimpo as for that, simply 1st mount the collet inside the nut, then start rotating the nut until you feel that the collet makes contact, or just squizes a little
    then reverse the nut like 1/2 turns, or something, so to make the collet be free again
    with your spare hand, put the tool in, and keep it there, while with the other hand, simply rotate the nut until the collet becomes tightnened
    then take a set of keys, or whatever, and tightnet them full
    i just realized, what i just wrote, works for a static spindles, and you have a router ?
    yeeeees, now i got it ! you see, when you have a router, you really look into collets, and i am more into cnc, and i don't care about collets not saying that a router is not something, nono, it issssssss
    i have never monted a tool inside a router, but using my imagination, i think you can use your mouth/teeht to keep the spindle static, and mount something with your hands ? hope attached image find you well
    i believe that you try to mount them all in one step, simply because your spindle, is not static ... is it so ? if yes, try to use a piece of wood or something, does it make sense ? if you wish, i will develop on that / kindly
    [F0NT=Verdana] Andrew Werby [/F0NT]
    [U4L="http://www.computersculpture.com/"] Website [/U4L]
    hey awerby, signatures are no longer formated, like from a few years ago
  16. #36
    Jun 2022
    24
    Got it.
    Actually, I measured for circularity inside the cone at three different height from the lower border of the spindle chuck (+2, + 6, +10 mm) but I understand it makes no big differences...
    So, in the end, the only way to have a chuck and collet correctly coupled is to have the internal surface of the chuck and the tapered surface of the collet "highly" parallel. In such way, when you insert the collet into the chuck is very rare to get them misaligned.
    I'm right?
    If the chuck of the spindle is tilted, then I think I cannot do anything about it. I'm right?
    How I can verify that? (Just for my personal curiosity).
    I was thinking to mount a long "axis" on my "precision collet" (will it be delivered to me). Unfortunately the toolbits I use are too short for that check (max 60 mm). I would need something 100 mm long as minimum.
    I can find a lot of cyclindrical axis on ebay, unfortunately their circularity is guaranteed, their straightness is quite crappy instead (I have some of them, and they are slightly curved like a banana along their longitudinal axis).
  17. #37
    Jun 2022
    24
    Yes, not-static spindles are a PITA for router owners like me.
    I love routers because they have a greater versatility. Furthermore, the big surface speedups your work by having a lot of different working sets on the same working table. I love this.
    I really do not understand why nobody designed an easy-to-use clamp to block the spindle axis in position while changing tool...
    Anyway, after a while, you get experienced in mounting collets on a non-static spindle. That is not the biggest problem here.
    My concern is about the "springed" nature of an ER collet: when you fit it in the chuck and keep it with some gentle rotations of your nut it can be sitting not perfectly because there is no tool-shaft in the collet.
    Some "springed" arc/segments of the collet can move and give you the false impression that the collet is fitted properly (i.e. perfectly parallel to the tapered surface of the chuck).
    If you now fit the tool-shaft (as second step of the mounting operation) the collet cannot expand/contracts anymore. It is blocked in his wrong position.
    As third step, you now tight the nut... et voilà! Your misaligned tool bit is served! : )
    So I tought that fitting the tool-shank inside the collet as first step would prevent it from expand/contract wrongly when you insert it inside the spindle chuck.
    But, as I said above, I could be wrong. Maybe there is a negligible difference here, and I'm just torturing my brain.... : ) : ) : )
  18. #38
    Jun 2015
    4154
    circularity inside the cone at three different heigh ... I understand it makes no big differences
    even if you measure at 3 different locations, and :
    ... have equal values, all amost 0, it does not mean that the chuck is ok, or not
    ... have different values, it may show wear, etc
    * once you get into alignments, simply have to check few different things, and once one is out of chart, you will have your answer
    I'm right?
    if the tapered contact, between chuck and collet, occurs ok, it means that the cone of the chuck, and the cone of the collet, both, are coaxial; let's call this the "main axis"
    how a collet is designed to have true id to it's cone, it means futher more, that if you clamp inside a tool, that tool axis will be almost coaxial to the "main axis" as long as clamping process remains true, thus the collet does perform well, etc
    if all is fine, then the tool/shank axis will be coaxial with the "main axis"
    If the chuck of the spindle is tilted ... How I can verify that? (Just for my personal curiosity).
    having your router in good condition, means that the "main axis" must be coaxial also with the spindle axis, and perpendicular to the table
    ... your story, with the cyclindrical axis; jog z axis, and dial the cilinder, among 2 lines, located at 90* phase difference; like once the dial has to be among x, then among y + tir check
    ... google "tramming a mill" or a router
    bananas have only longitudinal axis
  19. #39
    Jun 2022
    24
    I know how to tram a spindle. Thanks. I'm not interested in that.
    Your indications does not show if the cone of the chuck is tilted. They are a check for perpendicularity. That's a different stuff.
    This does not respond to my question.
    Do you have any suggestion of what I could buy to have straight reference on the spindle axis?
    A broken tool fitted in the collet? (But their are usually too short.)
  20. #40
    Jun 2015
    4154
    okey ... you wish to check tiltness in respect to what ? titness does not exist without a reference
    you reffer to the chuck cone, as not being true to shaft axis ? thus the cone to wobble in respect to ... ? please develop a bit ... i can't see
Page 2 of 3 123
  1. G0704 Z ball nut oiling
    By hscess in forum Benchtop Machines
    Last Post: 12-13-2016, 06:02 PM
  2. Collet nut imbalance
    By Azalin in forum Spindles / VFD
    Last Post: 08-01-2014, 03:14 PM
  3. Collet wrench for a ??? collet nut
    By burnettm in forum Want To Buy...Need help!
    Last Post: 12-28-2012, 09:14 PM
  4. ball screw/nut oiling
    By timbeaulieu in forum Bridgeport / Hardinge Mills
    Last Post: 07-23-2012, 08:56 PM
  5. Sherline Collet Nut
    By mikkojay in forum Benchtop Machines
    Last Post: 01-19-2008, 05:58 PM
