585,764 active members*
4,093 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Making CNC Dutch Oven lid
Results 1 to 8 of 8
    Jun 2010
    8
    Question Making CNC Dutch Oven lid
    I would love to design a Dutch Oven lid only!
    For bread making in a standard oven. Something like in the photo.
    Question: Is it possible to make it without casting? I wish to laser-cut the parts and bend the lid faces.
    Considerations: Heat resistance, sheet thickness, Emission of harmful gases while cooking, welding configuration of the parts.
    Any insights? Do's and Don'ts?Click image for larger version.
    Attached Thumbnails Attached Thumbnails ps-5q-do-bottom.jpg   ps-5q-do-bottom.jpg   ps_5q_do_bottom.jpg
    Apr 2018
    132
    Re: Making CNC Dutch Oven lid
    It appears your photo/attachment failed to upload properly (nothing visible).
    Jul 2018
    6325
    Hi And - 1) anything is possible 2) even though I can't see your image I'd ask; why a dutch oven in a std oven? a dutch oven is used in a fire pit. Its nearly pointless using a dutch oven in a std oven? Dutch ovens are thick to provide a stable internal temp as the fire is very hot and not uniform in temp. Cast iron is used as it holds heat very well so will again be stable in temp (plus if your going to make many lids and ovens casting is a cost effective process) . But I expect a mild steel version to be similar. Or do you intend to use it like a casserole dish? Some have cupped tops so you can fill the lid with ashes but doesn't sound like your going to do that?
    Anyways depending on how you intend to form it if you use soft mild steel you can english wheel it or pattern it then weld the bits together then wheel it or hammer form it... Mild steel will rust so you could do the same with aluminium or stainless steel. Indian metal workers are very good at hand hammering & shaping stainless, copper and aluminium. Peter
    Hi AND _ I did some reading on bread making in dutch ovens and it seems to me the"DO" is used to compensate for temperature variations in poorly controlled ovens , like old school timber ovens,. Modern ovens with convection and good temp control don't need the DO to create great bread. But have a go and post the image so we can see what shape your chasing. Peter
    Jun 2010
    8
    That's the photo I intended to show earlier.
    Jun 2010
    8
    That's a typical bread Dutch oven for the kitchen oven. It radiates intense heat to raise the bread, but you can use it for tender fish, meat, potatoes, and such.
Name:	2022-11-10 11_44_27-Best pris på Challenger Bread Pan - Se priser før kjøp i Prisguiden.jpg
    Attached Thumbnails Attached Thumbnails 2022-11-10 11_44_27-Best pris_p_Challenger_Bread Pan.jpg   2022-11-10 11_44_27-Best pris_p_Challenger_Bread Pan.jpg   2022_11_10 11_44_27_Best_pris_p_Challenger_Bread_Pan.jpg
    Jun 2010
    8
    My intention with this development is:
    Instead of buying a heavy Dutch oven with two parts, you could buy two voluminous lids covering the entire baking pan to bake two loaves of bread at once.
    I wish to use accessible CNC cutting parts and weld them myself instead of using industrial-scale methods like casting.
    Jun 2010
    8
    Low-carbon steel would be easier to work with, but high-carbon steel would be better for the task and easier to maintain and rust resistant.
    Can I laser-cut and bend high-carbon steel? Is the material available in 5-6mm thick sheets?Click image for larger version.
Name:	2022-11-10 19_32_15-The Challenger Bread Pan _ Challenger Breadware.jpg
    Attached Thumbnails Attached Thumbnails 2022-11-10 19_32_15-The_Challenger_Bread_Pan_Challenger Breadware.jpg
    Jul 2018
    6325
    Hi And - low carbon or high carbon steel will both rust. You will need to use stainless steel if you want to avoid rust. The DO does not itself radiate/generate heat. The oven its in heats the DO which has a slower thermal response then the oven itself (ie it has a higher thermal mass) so its internal temperature is more consistent. But then a good oven is all of that as well. Sorry none of your links work. Use the advanced tab below and attach your images vs using a link. Peter and yes you can laser cut patterns and weld together nearly any shape in steel, stainless steel or aluminium....
