584,842 active members*
4,717 visitors online*
IndustryArena Forum > CAM Software > Postprocessor for CAM > Syntec 210MA W/two multi-thread synch spindles (3 Axis), InventorCAM Postprocessor
    Apr 2022
    I'm very new to this, looking to order a Syntec 210MB controller CNC with two synchronized spindles to machine simultaneously travelling on a rail in the X-axis for long and skinny door parts. Is there an InventorCAM or Fusion 360 post processor available to post code for different profiles that can be input for each head separately (blocks, on same NC file) and run both heads, without manually having to paste the code in a master program. Has someone written a post processor for this application?
    thanks, any help/guidance much appreciated.
    Apr 2015
    327
    Re: Syntec 210MA W/two multi-thread synch spindles (3 Axis), InventorCAM Postprocesso
    Hello,
    if it is still actual, write me PM or on email [email protected]
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. Ref All Home, Slaved axis does not synch.
    By hkinkade in forum Machines running Mach Software
    Last Post: 12-12-2023, 02:35 AM
  2. Postprocessor SolidCAM (InventorCAM)
    By Danpil in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-24-2023, 07:56 PM
  3. Syntec multi drill
    By JWHMILLWORK429 in forum Postprocessor for CAM
    Last Post: 03-27-2022, 03:52 AM
  4. Multi spindles and nc studio 10v
    By shakibdriss in forum Complaints and Praise Discussions
    Last Post: 05-15-2019, 10:45 PM
  5. Mazatrol T Plus thread cycle in synch?
    By Castle1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2007, 04:22 AM
