585,992 active members*
5,533 visitors online*
    Nov 2022
    Red face The Circle is cut oval
    Hi
    First of all, I've read similar posts and tested all the listed steps, so suggest me new tricks, please.
    We have RD6442s laser cut machine. Recently we've noticed that circles aren't circles. We've tested 3 mm*3 mm circles and 10 mm * 10 mm. the odd thing is that the deviant isn't in the line of axes, it's in a line with about 50 degrees with one axe ( i didn't measure it). The start and final points are correct. Our machine was perfect previously.
    Our steps:
    1- Cutting 100 mm* 100 mm square and correcting the steps ( the difference was .1 mm).
    2-Lowering the speed
    3-Downgrade the software
    Steps we haven't done:
    1-Large circles (100*100 mm).
    2-changing the position of the circle.
    3-cutting a series of curves instead of a circle. (a circle with many points).
    4-Reupload of the frameware.
    If there is a mechanical failure such as backlash or missing steps; the start and final point weren't the same and the 100*100 mm square wasn't accurate.
    We don't find any software parameter which controls the pathway on a curve.
    What do you think?
    15362
    Re: The Circle is cut oval
    Quote Originally Posted by Shimidan View Post
    Hi
    Our steps:
    What do you think?
    The steps per mm are set incorrect, the square is telling you that.
    Mactec54
    Nov 2022
    We fixed it. How? cleaning the mechanical parts.
    15362
    So, you were losing position, from binding or lost steps
    Mactec54
  1. Not able to cut a simple circle :(
    By Mykeul in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-06-2019, 11:05 AM
  2. Need help Circle more like OVal
    By shanoger in forum Uncategorised WoodWorking Machines
    Last Post: 04-21-2015, 07:40 PM
  3. Replies: 6
    Last Post: 03-10-2015, 04:30 PM
  4. Circle cut problem
    By eragon9876789 in forum Mach Mill
    Last Post: 01-16-2013, 01:32 AM
  5. cut circle
    By bbrown2005 in forum Mach Wizards, Macros, & Addons
    Last Post: 02-05-2009, 01:41 AM
