585,555 active members*
3,379 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori MV40 w/ Fanuc 10M9B - Err 240 NO EMPTY POT
    Nov 2022
    So I'm sure I'm doing something wrong here - 1988 Mori Seiki MV40 with a Fanuc 10M9B control. We just bought it secondhand and it didn't come with any manuals, so we're a bit in the dark here.
    The machine is fired up, the spindle runs, everything looks like it should. I went into MDI and ran a T1M06 to try and set tools in the 20 place tool changer. As soon as I did, the error came up - 240 - EMPTY POT NOT FOUND. It forces me into an error screen and gives me the pages to either manually change the tool page, or run the ATC in manual mode (Pot up/down and arm forward/reverse). When I try to change a tool to 00 (there are no tools in the machine) nothing seems to change. When I try to move the tool changer by hand, I can move the pot up/down, but I can't seem to move the arm off of home position.
    I've attached a couple of photos below - any advice is welcome! I'm coming from a 2004 HAAS and a Milltronics lathe, so I'm sure I'm either spoiled or just missing something obvious. Any help is appreciated!
    Attached Thumbnails Attached Thumbnails Tool Entry Page.jpg   Alarm Code(2).jpg   ATC Manual Page.jpg
    Dec 2006
    16
    Re: Mori MV40 w/ Fanuc 10M9B - Err 240 NO EMPTY POT
    Not at all sure of this, but with the Fanuc controls, it needs the M06 first. And possibly use the tool number in 2-digit form, with a leading zero if necessary, and possibly add a second 2-digit number to include the offset for that tool... like M06T0101 (the second 01 would be the tool's programmed offset).
    Hope this helps.
    Holland Industrial Control Service
    [email protected]
    Nov 2021
    7
    I just did some fiddling with the same thing today, not sure what exactly did the trick but now I have it working. Try putting 0000 as the spindle tool and tool 0001 to some magazine slot and then input T1;M06; in MDI
    Jul 2022
    6
    Did you ever figure this out? I have the same machine but a 86 and its doing the same thing to me with the same empty pot not found.
  1. Replies: 3
    Last Post: 03-20-2022, 09:04 PM
  2. Mori Seiki MV40 with Fanuc 10M control tapping problem
    By onemanarmy920917 in forum Fanuc
    Last Post: 06-25-2021, 12:06 PM
  3. Replies: 27
    Last Post: 12-26-2018, 03:58 AM
  4. Mori Seiki MV40 with Fanuc OM-C
    By rai in forum Mori Seiki Mills
    Last Post: 11-03-2015, 04:30 PM
  5. Ladder Diagram for Mori Seiki MV40/Fanuc 6M-B
    By Randy K in forum Mori Seiki Mills
    Last Post: 03-06-2012, 11:21 AM
