585,974 active members*
4,338 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > FlashCut CNC > What the best CAM software to create G-code for turning with a Flashcut controller
    Im completely new to the CNC side of things, but I do understand some of it. I have an engineering back ground, just not the CNC programming side of things.
    I have Solidworks for CAD and i have been trying to use Fusion 360, but they do not have a post processor that works very well with the flashcut control software. I can make it work but there is something off with the profile. Its like its working of diameter settings instead of radius and I cant figure out how to change it.
    Later tonight I will post pictures of my model and pictures of what the piece turns out like when the program is done.
    Dec 2013
    5717
    Re: What the best CAM software to create G-code for turning with a Flashcut controlle
    Well, you could set your steps/inch (mm) to double (or the inverse?) what they are for the X axis. That would put into radius mode. As I recall Fusion only outputs diameter.
    Jim Dawson
    Sandy, Oregon, USA
    So i im sorry i never posted pictures. I sort of forgot about it. But I did figure it out. I use the fanuc post processor which works ok with some minor edits. The the X scale needs to be changed from 2 to 1.
    i found this line
    var xFormat = createFormat({decimalsunit == MM ? 3 : 4), forceDecimal:true, scale:2}); // Diameter
    and changed it to
    var xFormat = createFormat({decimalsunit == MM ? 3 : 4), forceDecimal:true, scale:1}); // Radius
    problem solved
  1. Replies: 0
    Last Post: 01-13-2020, 11:11 PM
  2. Create rough turning in ZW3D CAD/CAM
    By BryanMc79 in forum ZW3D CAM
    Last Post: 05-08-2012, 04:04 AM
  3. FlashCut Compact Controller and V4 software
    By mrehmus in forum FlashCut CNC
    Last Post: 11-28-2010, 03:33 AM
