585,975 active members*
4,402 visitors online*
    Modifying G code with existing database
    I make windows for historic properties. We're gradually moving to CNC machining all parts.
    I have one simple operation of milling a series of lines (actually coping boards) from X0 to X12 with anywhere from 1 to 12 cuts at various Y coordinates (think cutting rungs on a ladder) the depth is constant so the only thing that varies is the Y position the cut begins. I'll be doing this operation very frequently.
    Since the only variable is the Y, I calculated the values in excel and pasted them into the G-code into the appropriate lines with a text editor. Congruently, I have a fairly robust database, MS Access, that generates all my cut lists based on the window height and width.
    It occurs to me that I should somehow be able to generate the generic g-code in V-carve, save the NC file in Access, have Access prompt me for the the values I need and have it modify the code like a mail merge, then save the file again for use on my machine.
    Does anyone have experience with using a database program to, not necessarily generate the G-code but at least, modify code that's stored in DB files or records?
    Jun 2015
    4154
    Re: Modifying G code with existing database
    hy i can try to help you ... please share a video with actual aproach ( only flow, no comments ), and then share what you like or not, what you wish for, etc; i need to see
    simple milling a series of lines ... very frequently
    macro ?
    values in excel
    pasted to G-code , text editor
    database
    MS Access ,
    Access prompt
    V-carve
    save the file again
    seems too many steps / kindly
  1. tool database
    By Delloman in forum Vectric
    Last Post: 08-23-2018, 05:17 AM
  2. Nesting from existing G-Code
    By TheJollyMiller in forum Uncategorised CAM Discussion
    Last Post: 03-28-2015, 08:52 AM
  3. Modifying existing posts
    By DELL in forum Mastercam
    Last Post: 03-06-2013, 01:46 AM
  4. tool database 5.2
    By single phase in forum Hypermill
    Last Post: 11-15-2007, 08:30 PM
  5. Database help
    By rkruczk in forum Uncategorised MetalWorking Machines
    Last Post: 10-08-2006, 11:49 PM
