586,005 active members*
4,932 visitors online*
    Dec 2015
    5
    Teknic Clearpath PPR?
    I'm using Clearpath motors with the enhanced option on a plasma table running ESS/Mach4. I'm trying to determine what to set the PPR to when tuning the motors?
    Sep 2017
    39
    Re: Teknic Clearpath PPR?
    You don't specify which Clearpath servos you have but the enhanced versions are usually 6400PPR and one can change this resolution to suit you machine and needs. When you do the tuning this is automatically taken into consideration so just let the tuning do its stuff and follow the instructions. All I can say been using Clearpaths on my DIY CNC machine for 5 years now and no issues they are just very powerful accurate servos.
  1. Teknic Clearpath SD questions
    By NRW in forum Servo Motors / Drives
    Last Post: 04-04-2020, 06:12 PM
  2. Recommended Teknic Clearpath Motor for Prolight 2000 Retrofit
    By vinmancnc in forum Benchtop Machines
    Last Post: 03-20-2018, 10:45 PM
  3. PPR for Heidenhain in iso format
    By Gjh in forum Dolphin CAD/CAM
    Last Post: 05-20-2016, 02:17 PM
  4. PPR settings in TNC370
    By wahidbashir in forum Bridgeport / Hardinge Mills
    Last Post: 12-21-2010, 08:03 PM
  5. CPR PPR recomendation
    By wcarrothers in forum DIY CNC Router Table Machines
    Last Post: 08-31-2006, 09:04 PM
