585,967 active members*
4,270 visitors online*
IndustryArena Forum > CAM Software > CamWorks > CAMWORKS Coordinate System
Results 1 to 1 of 1
    Nov 2022
    I am new to cam works so I am trying to get a few things figured out. I am having an issue with the coordinate system not matching the mill part setup. For some reason my Y and Z are swtiched around.
    Mar 2008
    454
    Re: CAMWORKS Coordinate System
    Camworks coord system is pretty much identical to SolidCam.
    I'm guessing you are looking at the default alignment rather than creating a new coord system.
    I recommend starting with some youtube vids on the coordinate system... either SolidCam or CamWorks will do
    Aug 2011
    252
    Quote Originally Posted by LJEREMY578 View Post
    You need first to define your part coordinate system in camworks and just after that to make setups. Any mill part setup is related to the defined coordinate system.
