585,973 active members*
3,870 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Stepper motor NEMA17,11 rotor diameter
    Nov 2022
    Hello!
    Are there any blueprints available? Looking for a stepper motor with about 10mm rotor diameter.
    Thank you.
    Jun 2021
    105
    Re: Stepper motor NEMA17,11 rotor diameter
    I have never seen manufacturers give stepper rotor size details - diameter, etc... - as standard information in their documentation. Perhaps if they provide CAD models that show the internal parts, but I have never had the need for that.
    If you are referring to shaft diameter, most of the steppers I have come across in the Nema 11-17 size have had shafts that are usually half that diameter. That dimension is always provided, and often quickly found when using their online filters.
  1. Anybody know the shaft diameter for the stepper motor
    By jeffrey001 in forum Tormach Slant Lathe
    Last Post: 04-12-2020, 01:54 AM
  2. Preferred stepper motor shaft diameter
    By ahacking in forum Stepper Motors / Drives
    Last Post: 05-27-2016, 03:00 PM
  3. 3 axis CNC controller kit 3 NEMA17 78 oz-in stepper motor + 3 axis CNC board
    By Chaparro1973 in forum Stepper Motors / Drives
    Last Post: 03-12-2012, 10:26 AM
  4. Remagnetizing stepper motor rotor
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 04-11-2004, 02:47 PM
