I have a sharp 2412 vertical machining center (10 pos tool changer) and it has developed a problem clamping the tool.
It appears the cylinder/actuator is not letting the collet fingers come down far enough to grab or release the tool.
Air pressure is fine and I pulled the hose from top of cyclinder and there appears to be sufficient pressure. Any ideas???? Thanks, Matt
