585,568 active members*
3,262 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Speeding-up 775 motor from 12v power
Results 1 to 5 of 5
    Nov 2022
    4
    Hi, guys !
    This is my first post here and I am glad to join your community.
    I would like to get some advice on how to force my 775 motor on T8 CNC machine to rotate faster.
    I have SVEN PU-600AN (see photo) which gives enough power (480W /40A) for spindel and steppers, but limited to only 12V. To increase rotation speed I would like to step-up the voltage without losing the power. I see many DC/DC 12V/24V converters on the market, but they are very expensive (compared to my T8), so I am looking for optimal solution.
    Any suggestions, please !
    Thanks in advance.
    775 motor specifications:
    https://somanytech.com/what-is-775-motor/
    T8 specifications:
    https://hobbyking.com/en_us/t8-diy-3...-and-grbl.html
    Dec 2003
    24220
    Re: Speeding-up 775 motor from 12v power
    The simplest way is to use a 24vac transformer, use a bridge rectifier and a 200uf capacitor on the output. This will give you ~+30vdc to the motor, which is close to its limit.
    Albert E.
    Nov 2022
    4
    Thank you for reply, I have seen something similar and ready to use, but I am afraid that it has no enough power:
    https://www.aliexpress.com/item/1005004285958078.html
    Beeng software developer, I am not familiar with electronics, so some concrete schematics can help me a lot.
    Dec 2003
    24220
    If you know how to put one together, this is the circuit.
    Albert E.
    Nov 2022
    4
    Thank you very much, soldering is not a problem )
