585,722 active members*
4,465 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Fault light-- intermittent
    Oct 2014
    Hey gang-
    Been running my CNC router parts pro machine for ~ 10 years.
    Having an issue today where the E stop keeps triggering (i have no estop its jumped). I cleared it a few times and restarted trying to finish my part.
    It just triggered a minute ago in the middle of a cut (stayed triggered- leaving the emergency light flashing on the Mach3 diagnostics). I walked over to the G540 and the fault light was on. I could not clear the Estop in Mach3. Cycling the power on the conrol cabinet resolved the fault immediately.
    I'm wondering if my G540 has an issue.
    Is there a document somewhere that lists reasons this light could be on?
    Attaching a few photos of the setup
    Oct 2014
    Re: Fault light-- intermittent
    About an hour into websearching. I found this video: https://www.youtube.com/watch?v=ph-IFMQC_6E which suggests:
    This can be related to thermals, but more importantly related to the incoming power from what i believe is a switched power supply. It seems gecko is aware of this issue and has been reworking boards to remove a capacitor-- and provides guidance on how to do this.
    Emailing gecko now.
  1. G540 intermittent fault at power up
    By y0da900 in forum Gecko Drives
    Last Post: 07-30-2016, 02:59 AM
  2. Gecko 6203v intermittent fault
    By woodguy60 in forum Gecko Drives
    Last Post: 07-24-2014, 01:47 PM
  3. G540 intermittent fault light on power up
    By rogerfries in forum Gecko Drives
    Last Post: 02-05-2013, 09:55 PM
  4. G540 intermittent fault light
    By Ranscon in forum Gecko Drives
    Last Post: 01-24-2013, 03:24 PM
  5. Intermittent (but persistent!) G540 fault light
    By TiagoSantos in forum Gecko Drives
    Last Post: 08-02-2012, 08:23 PM
