585,753 active members*
3,826 visitors online*
Results 1 to 2 of 2
    Aug 2015
    37
    cnc lathe cutters
    Hi...anyone have experience with the kind of cutters in pic attached?...looking for a US source...also any advice would be helpful as well...Thanks,
    Rick
    May 2017
    56
    Re: cnc lathe cutters
    Hi Rick!
    Are you just looking for a tool to do OD profiling tool on your lathe? Would a 35 degree indexable holder and insert like this work:
    3/4" Shank RH Profiling Holder: https://www.toolhit.com/products/thc89585
    3/4" Shank Neutral Profiling Holder: https://www.toolhit.com/products/thc89191
    Inserts that would fit both holders above: https://www.toolhit.com/products/tmh00318
    If this would work we would just need to double check what shank size you need. Or if you had a specific profile you were looking to turn let me know and we can try to find other options!
    Hopefully this helps Rick!
    Mike
    www.toolhit.com
  1. Grizzly G0602z lathe 4 post holder is .3" to high for 1/2" cutters
    By garymetalwood in forum Benchtop Machines
    Last Post: 07-11-2019, 01:42 AM
  2. CNC Cutters
    By WB-1 in forum DIY CNC Router Table Machines
    Last Post: 06-30-2013, 01:20 PM
  3. LETTERING HARDWOOD CUTTERS? AND PLYWOOD CUTTERS
    By andycorleone in forum WoodWorking Topics
    Last Post: 12-12-2008, 07:36 PM
  4. CNC router cutters
    By bob1112 in forum Mechanical Calculations/Engineering Design
    Last Post: 02-17-2007, 01:26 AM
  5. cutters for cnc router
    By flyingmike in forum CNC Tooling
    Last Post: 11-08-2006, 09:06 PM
