585,568 active members*
3,339 visitors online*
Results 1 to 2 of 2
    Dec 2016
    51
    (Steel) Table Mating
    I have misgivings about mating Avid aluminum extrusions to a steel table. Part of the draw of Avid is that it's not a big, impractical to move machine- something it also suffers for. I'm seeking a middle ground, that space of compromise usually occupied by mediocrity. I want a relatively rigid table base I can break down and move, assemble, re-level, fill with sand for dampening, and build out the Avid machine base on.
    I'm good with all the basic fabrication of the steel elements, but can't quite reckon how to wed the aluminum extrusions in way that will both allow for tramming AND capture the benefits of the steel base. I'm sure this is a problem that has been confronted by many others before- any insight will be appreciated.
    15362
    Re: (Steel) Table Mating
    Quote Originally Posted by Mavigogun View Post
    There is more than one way to do this, if you want it to be easy to break down then you can add an aluminum plate / bar to the bottom of the extrusion and then you would have a flange around the bottom of the extrusion to bolt / fasten to the steel table, this would be your easiest way to do it, or direct bolt / fasten the extrusion to the steel table using T-Nuts in the extrusion and be able to bolt / fasten from underneath the steel table into the T-Nuts
    Another way is to machine pockets into the extrusion and you this type of fastener to direct bolt / fasten to the steel table
    Mactec54
  1. Hastighet på mating
    By nitrov in forum Norwegian
    Last Post: 10-09-2015, 10:06 AM
  2. Mating parts between assemblies?
    By Rich05 in forum Solidworks
    Last Post: 03-03-2011, 12:57 AM
  3. Mating servo's to drives
    By peterson76 in forum Servo Motors / Drives
    Last Post: 01-28-2010, 05:01 PM
  4. Mating, how to?
    By dneisler in forum Solidworks
    Last Post: 12-27-2007, 02:34 PM
