585,951 active members*
3,912 visitors online*
IndustryArena Forum > CAM Software > UG NX > Planar Wall Profiling troubles
    Greetings,
    My basic simple novice goal to determine the best Operation for Cookie Cutting some flat shapes from 1/8 Aluminum. I've reviewed 2D Profile Wall without Floor, 2D Profile Wall with Floor also Floor & Wall.
    2D Profile Wall w/o Floor...
    What is the suggestion for why the Toolpath is not closing while leaving gaps ?
    Is it the Engage or Start Drill Point that is causing the Gaps in the Toolpath?
    How do I remove the Gaps in the Toolpath? I have circled the Gaps with Green Pencil.
    Attached Thumbnails Attached Thumbnails CAM LAYOUT.C.000.jpg   CAM LAYOUT.C.001.jpg
    Re: Planar Wall Profiling troubles
    Gaps in the Toolpath review to be a configuration of the Non-Cutting Moves although I am unable to configure the attributes in such a way as to remove the Gaps in the toolpath.
    Nov 2016
    11
    Did you try creating a curve and between your objects and use follow curve?
  1. Planar curves
    By popspipes in forum Rhino 3D
    Last Post: 01-15-2016, 01:16 AM
  2. Planar finishing issue.
    By jeanyes in forum MadCAM
    Last Post: 10-03-2012, 06:47 PM
  3. Bends with non-planar faces
    By Bigtoy302 in forum Solidworks
    Last Post: 04-13-2010, 03:06 PM
  4. slice planar
    By skippyfix in forum BobCad-Cam
    Last Post: 08-14-2009, 09:01 PM
  5. wont planar
    By racefast in forum BobCad-Cam
    Last Post: 02-20-2008, 02:05 PM
