585,759 active members*
4,058 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Surfcam velocity 3.0 Flat Surface Machining
    Aug 2005
    21
    Im trying out the flat surface maching and it is wiping out my detail in the middle of the part and in the tool parameters their no option for surfaces to avoid or bounding box? any help would be great
    Feb 2006
    992
    creat a simple box geometry around the detail then after done with all the toolpath parameter, the software should ask for toolpath bounding........... unless Velocity 3 is change.
    The best way to learn is trial error.
    Jul 2007
    11
    You need to select everything, not only the flat surfaces but any adjacent details. The idea is that the software will automatically identify the flat areas, so you don't have to
    Nov 2005
    89
    When this happens to me I make a pocket toolpath from the surface boundaries (same tool and stepovers you want to use on the flat surface) and then use 3-axis project. When it asks which surface to project on select visible. After you use project, you probably won't use flat surface anymore.
  1. How to have surface table really 'flat'?
    By Sentinel in forum DIY CNC Router Table Machines
    Last Post: 04-02-2008, 07:06 AM
  2. Facing and getting a FLAT surface
    By SRT Mike in forum MetalWork Discussion
    Last Post: 05-11-2007, 08:22 PM
  3. Need post for Agie wire EDM Surfcam Velocity
    By sang sys in forum Surfcam
    Last Post: 12-09-2006, 04:16 AM
  4. Need post for Agie Wire EDM Surfcam Velocity
    By sang sys in forum G-Code Programing
    Last Post: 12-05-2006, 01:34 AM
  5. Surfcam Velocity
    By CrashedFadal in forum Surfcam
    Last Post: 06-21-2006, 05:33 PM
