I am doing a 4X8 router table with some belts for power transmission. I have been looking at different ways to hold tension. One is just to pull one pully away from the other. I think this would work when the distance is not to great but what about when the distance is 8 feet? Should I use a roller under and over the pullies to hold tension? Here is my Y axis. I am thinking with this that pulling one away from the other will work here. The issue will be when I mount this on the rails and the whole assy moves 8 feet. What are some solutions for tension on a long belt?
