585,715 active members*
3,844 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > calculatiing pinion size for rack and pinion setup
    Feb 2004
    427
    How do i work out what size pinion to use on a rack and pinion table setup. I will be most likely using NEMA 34's of the 470oz type i think. I will need to make the gantry to have the ability to move at least 500ipm.
    How do i work it out, is it possible to do it at this speed.
    I am thinking that buy having a bigger pinion the faster you go. Hopefully the NEMA 34's 470oz will have enough torque to move them at this speed.
    Any opinions
    Apples
    Jan 2004
    93
    Hello Apples.
    This is pretty straightforward calculations that you will find in most engineering books about machine elements. There is no difference in strength calculations whether it is rack&pinion or pinion&gear. You have the torque of your motor and acceleration of the pinion, so the tooth load can be found from that. The teeth is then basically designed from these parameters to withstand tooth breakage and pitting. For noise reasons it is better to have a smaller module and wider+more teeth than a bigger module thinner gear.
    regards
    John
    Jul 2003
    126
    Even with that high rate you will still need a gear box.
    1 revolution of motor will be pinion diameter * PI (3.1416)
    Without gear box, and 2k rpm ( max servo motor speed)
    1" pinion (smallest and slowest I have found)
    You will be moving at 6,283.2 inches a minute.
    12:1 gear box would be nice to add.
    Bigger pinion will require more gear box so keep that in mind.
    Aug 2003
    253
    500ipm is extremely fast. I'm trying to set mine about 100ipm.
    Nema 42 Big Honking Motors:
    Desired IPM (Inches Per Minute): 100
    Motor RPM: 2000
    Torque (oz/in): 1500
    IPR (Inches Per Revolution, Assume 1" Pinion for Rack) = 1*PI = 3.14159265" per revolution
    RPM Needed = Desired IPM / IPR = 31.8309887
    Reduction Ratio = Motor RPM / RPM Needed = 62.83
    Torque after reduction = Torque * Reduction Ratio = 94247.7795 oz/in (which really doesn't mean much as long as it isn't too low).
    Actually, I may try for a reduction ratio of 40 or less. But the above will give you the basic idea. I think I'm calculating it all correctly. Once you get the Reduction ratio you can pick your gearbox or pullys/teethed-belts. For pullys just divide the number of teeth on the big gear by the number of teeth on the small gear.
    72 teeth Pully/10 Teeth Pully = 7.2 Reduction Ratio (Use two sets and your in the ball park! 7.2*7.2 = 51.84 Reduction ratio)
    Ummm, I could be wrong about everything here!
    :rainfro:
    P.S. Did I mention that the pinion size is always going to be 1". That is the smallest you can get. Getting a larger one, considering your reduction ratio, would be insane, IMHO.
    Dec 2014
    Quote Originally Posted by samualt View Post
    Motor RPM: 2000
    :rainfro:
    Hello im doing a cnc table 4 x 4 and i buy rack module 2 pinion 20 tooth and i dont
    Know what gear reduction buy. Can any one help me on this?
  1. dual pinion rack and pinion anti backlash
    By johngalt47 in forum DIY CNC Router Table Machines
    Last Post: 06-12-2011, 04:04 AM
  2. Rack and Pinion- rack tensioned to pinion?
    By Rees Guitars in forum Linear and Rotary Motion
    Last Post: 05-09-2011, 06:05 PM
  3. Place to buy Rack and Pinion setup?
    By planekrazie in forum DIY CNC Router Table Machines
    Last Post: 12-08-2007, 05:56 AM
  4. Torchmate Rack and Pinion Size
    By techie4971 in forum Torchmate
    Last Post: 07-31-2007, 06:04 AM
  5. My Rack and Pinion setup???
    By flash319 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-01-2007, 12:45 AM
