585,568 active members*
3,467 visitors online*
    Sep 2007
    64
    Suggestions for CNC electronics
    Hello,
    I just purchased a Taig CNC ready mill and I would like to get suggestions on what electronics would be good for this mill. This is the 2019CR-ER if that makes a difference.
    My applications to start out with will be just playing and learning how to use the machine. Later I will be doing a lot of CNC drilling/milling in Lexan and hard aluminum. Id like to spend around $300-400.
    I built my own CNC router about 3 years ago but it was not all that accurate or quick. I used 80oz steppers and a HobbyCNC driver board. It missed a lot of steps and I had to move the axis very slow in order to get OK results. I noticed that hobby CNC has a 4 axis setup with 4 305oz motors for $335. Is this a good setup?
    What would you recommend? Thanks!
    Edit: I just found this package from xylotex, http://www.xylotex.com/3AxSysKit-425.htm
    It looks like a better package than what hobbycnc offers. What do you think?
    Also, how would I handle home/limit switches?
    Mar 2004
    261
    Try this site for research: http://www.cartertools.com/
    Many, many links. Personally I use HobbyCNC and Keling steppers. All works very well.
    RipperSoftware
    Sep 2007
    64
    hey ripper,
    I have been around cartertools before but cannot really find the info I need. One concern I have right now is home/limit switches, coolant activation, spindle speed, etc. With the gecko and xylotex controllers, how do you obtain this functionality?
  1. I need to know everything about CNC Electronics
    By alanfreefall in forum Servo Motors / Drives
    Last Post: 07-19-2007, 02:56 PM
  2. DIY Electronics question
    By CNC Darren in forum Hobbycnc (Products)
    Last Post: 02-14-2005, 04:32 AM
  3. Electronics
    By Bassbuilder in forum CNC Machine Related Electronics
    Last Post: 11-16-2004, 04:34 AM
  4. Help with electronics 101
    By bb99 in forum CNC Machine Related Electronics
    Last Post: 11-15-2003, 12:03 AM
  5. Electronics help
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 07-18-2003, 03:09 PM
