585,931 active members*
3,828 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 Carousel Drum # Wrong
Results 1 to 5 of 5
    Jan 2023
    Cool Fadal 4020 Carousel Drum # Wrong
    Our Fadal has a Fanuc Oi-MC control. The physical location of the drum is 3 spaces from where the control thinks it is. That is, I set drum 4 with tool 6 and when I call up T6, the drum will go pull from drum 1. The control will then display drum 4 as the current position. Could someone help me reset my carousel position relative to the control? I am fairly new this so any help would be appreciated.
    Thank You,
    Andy
    Oct 2008
    1632
    Re: Fadal 4020 Carousel Drum # Wrong
    Have you tried using the command SETTO ? This will establish this location astool number one. From there the count should be correct.
    Richard
    Quote Originally Posted by AGilmour View Post
    Thank You,
    Andy
    Aug 2009
    1573
    ...Fanuc not sure--- but we learn fast.
    Oct 2008
    1632
    Sorry, I didn't see the Fanuc when I read it. Who Knows? hopefully someone with more experience chimes in.
    Aug 2009
    1573
    ...we all three learning something. I found TC reset in a Fadal manual for Fanuc control Chapter 7.3
    https://flintmachine.com/images/uplo...tor_Manual.pdf
    Also, the Siemens control Restore Magazine Count page 107
    https://flintmachine.com/images/uplo...nce_Manual.pdf
  1. Replies: 4
    Last Post: 02-07-2018, 05:25 PM
  2. Fadal carousel engagement
    By Houndogforever in forum Fadal
    Last Post: 03-14-2016, 10:49 AM
  3. Fadal 4020
    By ghm195 in forum Fadal
    Last Post: 04-23-2012, 06:17 PM
  4. Fadal 4020
    By LatheCrasher in forum Fadal
    Last Post: 02-17-2012, 03:23 AM
  5. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
