585,970 active members*
4,600 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD YL620-A P00.06 Highest output voltage ??
Results 1 to 6 of 6
    Dec 2005
    313
    Hi..
    I want to connect a BLDC bodine 34B6FEBL to a VFD YL620-A
    https://www.bodine-electric.com/prod...dc-motor/3409/
    The motor is 130 volt.
    The input voltage on the YL620-A is 220 Volt.
    Can this setting:
    P00.06 Highest Output Voltage 10.0% - 150.0 %
    be used to set the output of the YL620-A to 130 volt ??
    How does this work ?
    Is this how to do it ?
    ( 130 / 220 ) * 100 = 59
    SET P00.06 59 ???
    Attachment 488528
    Any other suggestions on how to make this work ?
    Thanks.. Vroemm...
    15362
    Re: VFD YL620-A P00.06 Highest output voltage ??
    Quote Originally Posted by vroemm View Post
    Hi..
    Can this setting:
    SET P00.06 59 ???
    Attachment 488528
    Thanks.. Vroemm...
    That VFD Drive or any VFD Drive is going to have a very hard time driving a BLDC motor, these VFD Drives are only for 3 Phase AC motors not for DC motor you have.
    You would need a Drive like this to make it work / run.
    Mactec54
    Dec 2005
    313
    Thank you very much. Very useful.
    The driver you mentioned is hard to get and very expensive.
    I tried to find a cheaper BLDC controler.
    But found none.
    Am i overlooking something ?
    An arduino BLDC controler suitable for this motor or something ?
    Are there BLDC controlers which work with lots of different BLDC motors ?
    15362
    But found none.
    Here is some links I'm sure there are many suppliers, Check on Ebay as well.
    https://github.com/pekkaroi/bldc-drive
    https://www.anaheimautomation.com/ma...1d90a408e322ed
    https://www.made-in-china.com/produc...top&log_from=1
    Mactec54
    Dec 2005
    313
    Thanks..
    24221
    But found none.
    A lot depends on how that motor expects to be commutated, IOW, does it have three commutation sensors or is there just the three 3ph motor leads?
    If it has sensors then you can look at some of the used servo motor controllers from A-M-C etc and run it open loop.
    If no sensors then you require a drive that is capable of self commuted operation.
    Albert E.
  1. VFD error 4 YL620
    By zhongche in forum Spindles / VFD
    Last Post: 10-13-2021, 07:49 AM
  2. YL620-A VFD setting question.
    By regpye in forum Spindles / VFD
    Last Post: 03-25-2021, 12:44 PM
  3. Vfd YL620-a initial setup
    By Terryble24 in forum Spindles / VFD
    Last Post: 12-20-2020, 05:04 PM
  4. Replies: 1
    Last Post: 10-19-2017, 12:48 PM
  5. Replies: 0
    Last Post: 03-20-2017, 12:35 AM
