585,700 active members*
3,527 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Problem with wrap junction in rotary V-carve program
    Aug 2014
    11
    I'm new to Aspire and having an issue with blending the junction between both ends of the profile I'm trying to wrap around a dowel. The profile is a chain link design that starts & ends in the middle of a link. If I leave the ends open, I can't generate a program. If I close the ends, I end up with a ridge at the junction because Aspire sees this as part of the v-carve profile. Attached pics shows the junction in a few different ways. To give you a sense of the size of this, the chain links are .200" wide and the dowel is 1.112" diameter.
    Any help is greatly appreciated. TIA.
    Aug 2014
    11
    Re: Problem with wrap junction in rotary V-carve program
    I extended the lines beyond the work surface and closed them. That helped. It still shows some misalignment but won't be visible to the naked eye.
    Thanks!
    Apr 2022
    135
    Are you using Mach3/4?
    Aug 2014
    11
    Mach 3 but I don't see what difference that would make.
  1. Wrap Feature around X Axis Problem
    By j206 in forum FeatureCAM CAD/CAM
    Last Post: 12-15-2020, 04:31 PM
  2. Replies: 2
    Last Post: 09-03-2014, 08:08 PM
  3. Need pinouts: Anyone have Nikken 5AX-120YA and Alpha Controller with Junction Box?
    By torinwalker in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2013, 04:07 AM
  4. Rotary Tutorial for Aspire & V-Carve
    By rcnewcomb in forum Vectric
    Last Post: 05-17-2010, 12:06 AM
  5. problem with depth in v carve
    By timmyb199 in forum Vectric
    Last Post: 11-01-2006, 06:42 AM
