585,975 active members*
5,020 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCU VM2 Wrong toolchange height
Results 1 to 3 of 3
    Nov 2017
    13
    I am experiencing a problem with my toolchanger height. During toolchange Z axis goes to position that is too low and tool arm hits the spindle housing. This happened once yesterday after startup and calibration. I performed toochanger reset manually and it worked correctly after that. Today again it is hitting the spindle housing. After resetting and recalibrating machine, it goes to the wrong position. When I go into toolchange troubleshooting the machine shows it is a t toolchange height when it isn't.
    Jan 2013
    474
    Quote Originally Posted by pttech View Post
    Is your axis motor to ballscrew coupling slipping or broken ? Losing position during movement.
    Nov 2017
    13
    Re: HURCU VM2 Wrong toolchange height
    Quote Originally Posted by servtech View Post
    Hi, thanks for responding. I was able to talk with a HURCO service rep who put me on the right track when he told me to check for a sticking Z Axis limit switch. It was easily accessible, and I was able to spray some WD40 on it and free it up. All is good now.
  1. Replies: 1
    Last Post: 06-13-2020, 01:25 PM
  2. Help wiring Tool Height/ Z axis height base into C10 BOB
    By SpecialEd in forum Tormach Personal CNC Mill
    Last Post: 11-21-2016, 02:13 AM
  3. SCM Xilog adjust toolchange height
    By derek_Hampton in forum CNC Machining Centers
    Last Post: 01-04-2015, 03:44 AM
  4. Hurcu KM Quill
    By Bob La Londe in forum HURCO
    Last Post: 09-17-2014, 04:33 AM
  5. PyCam wrong safety height?
    By scales11 in forum Uncategorised CAM Discussion
    Last Post: 10-29-2013, 02:23 AM
