Originally Posted by
Marronrobby
If you want to buy a small metal machine, you're in the right place. Depending on your budget and the projects you want to do, you have a lot of different choices. Mini metal lathes can be used by pros, hobbyists, and even businesses.
They are easy to use, not too expensive, and can work with a wide range of materials. A mini metal lathe is a great tool to have in your shop if you want to make a custom part, turn a small item, or just learn how to work with metal.
