O.K., I'm stumped and need help.
My 3016 (2000 model factory reman) ATC turret motor is inop and I cannot figure out why. When I hit CCW/CW it will not start on its own but if I twist the shaft end it will run as long as you hold the CCW or CW key down...let it go..won't move again without assistance. I pulled a motor of my 4020 and it seems to work better ( no load on it...out of the changer and just laying there) but not bullet proof and it is an old big format fan cooled motor. When I put the inop 3016 motor over at the 4020...IT works there.
I had a new motor sent in, put new relays at K11 and K12 , K5,6,33 and new fuses at F5 and 6 and 2 new capacitors at C1 and C2..when I hit the CCW/CW keys, the motor hums (just like it did on the other two) and errors out if I don't assist it in starting. I am getting a red light constant on mech. relay K33 and a red light on mech. relay K5 after attempting to activate CW/CCW,. I don't see either of those activated on my 4020.
What the heck am I missing? I know its got to be something simple, but my Fadal phone tech can't help (other than suggesting a 913.86 1100-2 board on top of the 471.99 motor). The slide motor works fine.
Thanks for any help .
Kentsui
