585,978 active members*
4,285 visitors online*
Results 1 to 9 of 9
    Sep 2007
    7
    Cincinnati VMC Sabre 750
    Any quick answers on setting zero point on a part in order to program.
    I do what the book says and get errors. I just need to know how to set X,Y,Z
    Zero
    dng
    Mar 2007
    168
    What control does it have on it?
    Sep 2007
    7
    Cincinnati Milacron
    It has a Acramatic 850 Controller. Any help will be appreciated.
    Danny
    Apr 2005
    14
    Use G92 in MDI.
    If you pickup center of a hole and that will be zero in MDI enter
    G92X0Y0
    If you edge find (.200 edge finder) the left side of a piece in X use
    G92X-.1
    hope that helps! I don't have an 850 controller, but I do have a program manual here. Also I think it works the same as the A2100 controllers.
    Sep 2007
    7
    Acramatic
    I used to do some programming on CNC, so i am very rusty. Do you have any sample peck drill NC programs you could let me see. I have a manual, but it is written for the experienced programmer. I just need a sample to get me started. Any help would be appreciated.
    dg
    Apr 2005
    14
    Our Cincinnati machines here at work all have the A2100 controller.
    I think the programs are similar, but try this stuff at your own risk. Be careful!
    This will drill 2 holeS 1" apart starting at X2Y2.
    :G0G90 <---RAPID MODE ABSOLUTE
    M6T1 <---- TOOL CHANGE TOOL 1
    (MSG, SPOT DRILL) <--- MESSAGE BLOCK DONT KNOW IF 850 CAN USE THESE
    S600M3 <---SPINDLE CLOCKWISE 600 RPM
    GOX2Y2Z3 <--- RAPID TO POSITION
    M8 <--- COOLANT ON
    G81Z-.25R0W.1F2.5 <--- DRILL FEED IN RAPID OUT .25 DEEP FROM R PLANE OF 0 (Z ZERO) RETRACT Z .1 FEED IS 2.5 IPM
    X3W.1 <--- NEXT HOLE RETARCT Z.1
    G0G90 <--- CANCEL DRILL CYCLE RAPID MODE ABSOLUTE
    M1 <--- OPTIONAL STOP
    M2 <---END PROGRAM
    If you want to peck drill say 1/2 deep change the G81 line above to:
    G83Z-.5R0W.1F2.5K.1J13
    G83 is peck cycle K is distance to peck J13 is peck full out. Change to J11 for chip breaker.
    Let me know if it helps or if you need anything else.
    Sep 2007
    7
    Spindle Drive Fault
    I came in this morning to a Spindle Drive Fault on our Cincinnati Milacron. When I try to load a tool, it faults out and spindle turns slow. Any ideas. I know what the book says to do, and that's call a service rep. Is there a way to reset spindle drive?
    Dg
    Apr 2005
    14
    We have seen drive faults here from things liek power drops or even crashes.
    Normaly we can shut the machines down, including the breaker to the machine, wait a few minutes and power everthing back up.
    If the machine aligns properly it should be OK.
    I have never seen a machine based on the 850 controller. On ours
    the particular servo drive controller in question usualy displays an error code when there is a problem
    May 2009
    5
    does anyone have a pdf. of a cincinatti 750 operators manual? i just started working for a new company and thats what they have. im used 2 haas & fadal. my forman has been running these machines for 15 years and he is a condicending a** he expects me to be as fast at on the fly programming as he is and its pissing me off!!!!!!!!!
    so i thought i would try and get a copy of the manual and study it at home and try to get up to speed with him & get better than him.
    thanks !!!!!!!!!!!!!!!!!
  1. Cincinnati Sabre 500
    By leggetmachine in forum Uncategorised MetalWorking Machines
    Last Post: 05-16-2011, 05:14 AM
  2. Questions and/or Opinions about Cincinnati Sabre/Acramatic 2100
    By flyinphill in forum MetalWork Discussion
    Last Post: 10-29-2008, 11:10 PM
  3. Cincinnati Arrow vs Sabre
    By MITYDR in forum Uncategorised MetalWorking Machines
    Last Post: 07-20-2007, 11:35 PM
  4. cincinnati sabre parts
    By LUNCH TIME in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2006, 04:47 AM
  5. Help on Cincinnati Sabre 1000
    By alexanderrt in forum Hard / High Speed Machining
    Last Post: 03-01-2006, 05:30 PM
