585,925 active members*
3,452 visitors online*
    May 2007
    20
    Stamp engraving
    Hello,
    I have an 80W wklaser cutter and I'm tring to engrave some stamp on the classic gray stamp rubber, but I'm finding some difficulties wth the setting, can someone tell me a what are the best setting for this?such speed, power, width and gap?
    Ah, I'm using laser cut software
    Many thanks
    Apr 2007
    641
    Hi Paiox, speed between 500 -1000, power 50% to 80% depending on the speed, the gap is the normal lense gap (Focus heigth Luis
    Sep 2007
    11
    you can start with a gap of 0.042 which is equivalent to 600 dpi resolution
    lamicron, do you have a Chinese machine that can run at 1000 mm/sec??
    Apr 2007
    641
    You can do it engraving in any chinese machine, I think the work area is important, if it is too little you will only have acc and dec, will not get the real speed , in 900mm x 600 it works ok.
  1. Fun With Engraving...
    By 10bulls in forum CamBam
    Last Post: 03-25-2008, 03:18 AM
  2. Error message with Basic Stamp 2 editor
    By Lston in forum PIC Programing / Design
    Last Post: 08-07-2007, 05:17 AM
  3. 40W "stamp maker" laser engraver problem
    By frgt1000 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2007, 09:45 PM
  4. Cnc Y Basic Stamp
    By antares813 in forum Spanish
    Last Post: 02-01-2007, 04:51 AM
  5. Basic Stamp to control stepper motors?
    By phantomcow2 in forum Stepper Motors / Drives
    Last Post: 12-04-2005, 10:11 PM
