585,949 active members*
4,203 visitors online*
IndustryArena Forum > Material Technology > Glass, Plastic and Stone > Best method for cutting down delrin?
Results 1 to 6 of 6
    Sep 2007
    11
    So I have some 12x12 acetal plate, whats the best way to cut this into 3" sections?
    Aug 2005
    828
    I would use a wood table saw or skilsaw with a guide clamped to the plastic plate to get straight cuts.
    Dennis
    Sep 2007
    11
    Any recommendations on blade type to use?
    Sep 2007
    45
    Sawing Plastic
    As long as it is sharp, it will cut it! We use a carbide toothed blade with great results!
    Sam
    Sep 2007
    11
    awesome thanks guys. was worried about # of teeth etc. will have to go pick up a new blade to cut these down while waiting on my HF X3.
    Jul 2005
    12177
    Quote Originally Posted by chakup View Post
    Get what is called a Triple Chip blade. It will be labelled for cutting plastic and nonferrous metals.
    It is possible to cut Delrin with a sharp wood blade but you get a much smoother cut with less blade vibration using the triple chip blade.
  1. cutting data for Delrin and High Molecular Weight Polyethylene
    By jedioliver in forum Glass, Plastic and Stone
    Last Post: 11-14-2006, 02:23 PM
  2. What method will be more accurate?
    By DennisCNC in forum Mechanical Calculations/Engineering Design
    Last Post: 09-01-2006, 11:44 PM
  3. Best method to make this
    By Moondog in forum Uncategorised MetalWorking Machines
    Last Post: 10-07-2004, 11:49 AM
