585,589 active members*
3,572 visitors online*
Results 1 to 6 of 6
    Oct 2007
    Question Mazatrol M640 Fusion
    I am trying to transfer all the machine settings from the M640 onto a floppy disk, so that I can import that info into some machining software.
    Any ideas?
    Jul 2006
    14
    What software are you planning to use these machine settings in?
    Oct 2007
    It's going into Mazak Camware Turning Expert software
    Jul 2006
    14
    Can't you use the data I/O to save to the floppy?
    Oct 2005
    CamWare
    Simply use the cable to the Rs232 port and attach computer to the machine.
    When you are setting up the machine in camware click the machine button and the software will tell you you are allowed to load Tool Data User Parameters etc set the machine up to download these and push the start button.Alternatively save these to floppy and use the 640 floppy button instead of the machine button this will work as well
    Feb 2006
    992
    yes... you can read floppy and transfer parameter blah blah blad.... it's under Machine Manager User.
    The best way to learn is trial error.
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. VMWare Fusion for MAC
    By WayneHill in forum Computers / Desktops / Networking
    Last Post: 07-24-2007, 10:58 PM
  3. CNC Fusion
    By Memran in forum Benchtop Machines
    Last Post: 04-04-2007, 12:20 AM
  4. CNC Fusion kits
    By Redline in forum Benchtop Machines
    Last Post: 11-02-2006, 01:22 AM
  5. mazatrol pc-fusion 640 error....
    By monkei in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-03-2006, 12:42 AM
