585,975 active members*
4,539 visitors online*
Results 1 to 3 of 3
    Sep 2007
    11
    discusion- Max engraving speed
    Hi all,
    most of the Chinese machine brand will advertise that their max engraving speed between 50000 mm/min (833 mm/sec, 33 ips) and 72000 mm/min (1200 mm/sec, 47 ips)
    let us know what is you machine brand and what is the max speed you can reach before it start to jump and loose position (regardless of engraving quality)
    I'll start ,
    brand: "Laser world" yh9060C
    dvertised speed 50000 mm/min (833mm/sec)
    max I can get: 650 mm/sec
    please share your experience
    Apr 2007
    641
    My machine is from Zhongtai, I can reach the 1000/sec but sometimes it jumps out and start to jump crazy, sometimes it depends on the drawing, I have not found yet what is the problem, in some jobs work ok , others I cannot make over 600 or 700
    Jul 2007
    78
    My U.S. made Epilog is rated 65" per second (1651 mm) and I almost always run it at 100% speed with no problems.
  1. My New CNC engraving
    By dcarr in forum Engraving Machines
    Last Post: 12-23-2007, 12:59 AM
  2. Engraving with High Speed Spindle
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 06-27-2007, 01:25 PM
  3. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  4. which speed for steel and bones engraving?
    By jaru-eri in forum Benchtop Machines
    Last Post: 06-20-2006, 01:35 PM
  5. min speed exceeds max speed for axis "x"?
    By ljoe1969 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-19-2004, 02:49 PM
