I have yet to get anything from solidworks running under EMC2. I have successfully gotten a .DXF file from solidworks into MACH3 using both Lazycam and Ace Converter.
When I try to use the same .nc file that worked under MACH3 from ACE, EMC2 will spit out a bunch of errors, mainly about no feed rate and some other stuff. It will also not display the part in the viewport.
I need a solution, I love EMC2 Compared to MACH3, not because its free but because I feel MACH3 is full of useless buttons, EMC2's interface is much more streamlined.
Basically I can get a good .DXF file from Solidworks, but I cannot get any further in terms of GCode that works with EMC2.
